Topics that are moved into this category are considered to be closed. Users may want to add additional information but these topics should not be resurrected in order to discuss new problems or unrelated matters.
Merged K 3.0.3 Template Manager (Blue Eagle) "Blend with Joomla" setting does not work with J 3.2.0
12 years 10 months ago - 12 years 10 months ago #150371 by Thijssen
Hi
In the past I succeeded to let Joomla use my site template as the Kunena template.
I can't find a way to use my Joomla template in Kunena with Joomla version 3.2 and Kunena versions 3.0.3
Has anybody a hint? Using the blend switch in the bottom of the settings from the BlueEagle template doesn't do the trick anymore.
Thanks in advance
Last edit: 12 years 10 months ago by Thijssen.
12 years 10 months ago #150399 by Thijssen
Hi
I checked this against a fresh Joomla installation with 3.1.6 and 3.2. This is an issue between Kunena/BlueEagle and Joomla 3.2. The template gives errors with joomla 3.2. You can see this in the configuration screen of BlueEagle.
{HT}
12 years 10 months ago #150402 by sozzled
Thijssen wrote: The template gives errors with Joomla 3.2. You can see this in the configuration screen of Blue Eagle
Perhaps you can help us if we knew more about your site and the errors that you are getting. I have been using J! 3.2.0 with K 3.0.3 and I do not see any errors (in the Kunena Template Manager) when I set Blend with Joomla = Yes
12 years 10 months ago - 12 years 10 months ago #150404 by rich
I can confirm this issue. Please go in the Kunena Template Manager and save the setting again. Than it should work.
Please also look whether "Display Kunena Menu" is set to yes. Otherwise disappear the Kunena tabs after save.
I've reported it:
github.com/Kunena/Kunena-Forum/issues/2104
Last edit: 12 years 10 months ago by rich.
12 years 10 months ago #150422 by Thijssen
Is more info still necessary as it is alreayd confirmed? I can send you screenshots and test things as I have a testsite for it at the moment.
The error I see is :
Forum Header Background
Warning: strtolower() expects parameter 1 to be string, array given in /home/xxxxx/domains/yyyyy/public_html/a32/libraries/joomla/form/fields/color.php on line 166
{HT}
12 years 10 months ago #150427 by rich
Thanks, but this info should be enough. This error generates the wrong settings in the template manager. If it is fixed, everything should work again.
Time to create page: 0.452 seconds
