Merged J! 3.1: Ordering categories doesn't work
rich wrote: *** Topics merged ***
Welcome to Kunena, AdamRawR!
This is a known issue in Joomla 3.1.5 and it is be fixed in the next update (or you use the temporary solution posted in msg #5).
That's wonderful news, thank you!
components/com_kunena/views/category/view.html.php
to apply the fix mentioned in msg #5
I could not find the lines of code mentioned here:
github.com/Kunena/Kunena-Forum/pull/1912/files
on top of that the code in my file seems to be overall somewhat different than the file on github.
for example:
I am using Kunena 3.0.2 and Joomla 3.1.5
any insights? very grateful thanks!
- Thank you received: 2545
The correct path is:
administrator/components/com_kunena/views/categories/view.html.php
How to chnage order of categories on forum?
I tryed with first column (sorting) to drag categorie and drop below and on administration panel but then if i klik on publish button it back same as was. You can see on link how i make it.
