- Thank you received: 2545
Question Configuration problem after an upgrade from K6.3 to K6.4.2
1 year 6 months ago #233275
by rich
Configuration problem after an upgrade from K6.3 to K6.4.2 was created by rich
First go to Kunena -> Templates in the backend and check if Aurelia is marked as default.
Do you have any custom CSS codes for Blue Eagle in your Joomla custom.css? If Blue Eagle cannot be uninstalled, it should be enough to remove the Blue Eagle folder from /components/com_kunena/templates.
The topic has been locked.
- anonymous01
- Premium Member
- Thank you received: 11
1 year 6 months ago #233286
by anonymous01
Replied by anonymous01 on topic Configuration problem after an upgrade from K6.3 to K6.4.2
This happens from time to time, the kunena forum stops updating. This is the reason for my question. At the moment the version of the forum on my site is 6.3.10, is this the current version?
Why kunena does not offer automatic updates? This is a permanent bug, is it possible to fix it?I'm running Joomla 5.3. I manually upgraded to Kunena 6.4.2 as auto update did not work.
1 year 6 months ago #233287
by rich
Replied by rich on topic Configuration problem after an upgrade from K6.3 to K6.4.2
The automatic update should normally always be displayed.
However, we have omitted it from K6.3 to K6.4, as many website operators still use PHP 7, but Kunena 6.4 requires at least PHP 8.1.
The current version is Kunena 6.4, and if this is installed, the automatic update will be displayed again.
- anonymous01
- Premium Member
1 year 6 months ago - 1 year 6 months ago #233288
by anonymous01
After the update to 6.4.2, the topics from “Recent Posts” disappeared, the forum name went to “kunena” by default, all forum threads now publish the moderator's nickname. There may be other nonsense (I didn't check). What are you guys doing? If kunena 6.4.2 is a beta or unstable version, it should be reported in the release notes.
UPD. These bugs are a slap in the face to your users. Guys, show some respect for the people who rely on your product!
Last edit: 1 year 6 months ago by anonymous01.
- Thank you received: 188
1 year 6 months ago #233289
by Pinkeltje
Replied by Pinkeltje on topic Configuration problem after an upgrade from K6.3 to K6.4.2
Unable to reproduce. Did you go to Kunena Dashboard after installing K 6.4.2?
- anonymous01
- Premium Member
1 year 6 months ago - 1 year 6 months ago #233294
by anonymous01
I'm already used to the fact that you can't reproduce the issue. My web projects are hosted on AWS, so it's not hard for me to show you the described problems on a live site and then restore the site's original state. However, this also takes some time and effort. Perhaps you could manage to reproduce it yourself?
of courceDid you go to Kunena Dashboard after installing K 6.4.2?
