Solved No number behind Posts and Karma
9thmestore wrote about an error while migrating to Kunena 6.
They say I can fix it by uninstalling the Kunena component and then reinstalling Kunena.
It doesn't work with Aurelia either, so it can't be a Kunena template.
But if I uninstall the component and then install Kunena again, it doesn't solve the problem for me.
Does anyone here know how I can fix this?
Best regards,
Wouter
I had made some fix for it in 6.1.0 developpement version, the stable release could be released in one or two weeks
I hope you will release it soon.
Best regards,
Wouter
Because even after this update, the data (numbers) that should appear behind Posts and Karma will remain gone.
I also didn't read anything in the change log that there would be a fix in 6.1.0
Best regards,
Wouter
The fix has been made for Aurelia which is the official K6.x template, so if you are using a third party template you need to ask to the provider of the template.
But also with Aurelia.
With both templates I have this issue.
I don't know if this is an issue with Kunena itsilf.
Is there an option to check that?
You can see it here:
bmwcruiser.nl/forum/evenementen/839-geza...renspalen-met-belgie
Best regards,
Wouter
