Solved Problem for replying, editing/erasing posts
4 years 3 weeks ago #226250 by webbee
I just installed Kunena 6.0.3 on a Joomla 4.2.2. Most of settings are "default".
As I want to use forums in connections with Community builder's groups I made all appropriate settings and created several Sections and Categories.
Until then ... everything is working properly.
As a community builder user I created a first topic .. and there problems started:
1/ if someone want to reply to my post, only  the "quick reply" is functionning, not the normal reply.
2/ then, I found no way to edit or erase this topic.  the button "Action" is not working, not giving access to any possibilities.
As I though it could be a problem using this connection between Kunena and CB, I created a new section, a new category, and a new topic directly in Kunena,  just as a normal Joomla user.
Same problems occur for replying, editing or erasing a post.
Any solution ??
Thanks in anticipation for your help.
4 years 3 weeks ago #226262 by Leen
Also already tested with joomla > Global Configuration > SEO
Search Engine Friendly URLs <> yes/no
Use URL Rewriting <> Yes / No
to test various settings
can you send a Kunena Forum: Tools > Configuration Report
post here.
With kind regards
Leen
4 years 3 weeks ago #226266 by webbee
Here is the Configuration report :
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 192M | Max file upload:
Joomla default template details : shaper_helixultimate | author: | version: 2.0.11 | creationdate: Feb 2018
Kunena default template details : Aurelia | author: Kunena Team | version: 6.0.3 | creationdate: 2022-09-22
Kunena template params:
Kunena version detailed: Kunena 6.0.3 | 2022-09-22 [ Git Repository ]
Plugins: None
4 years 3 weeks ago #226267 by rich
Go to Aurelia settings and choose "Load bootstrap css = No" then try to reply.
4 years 3 weeks ago #226268 by webbee
It works !!
Wonderful ... you saved my day ! /media/kunena/emoticons/
Have a nice week-End !
Time to create page: 0.153 seconds
