Kunena 7.0.8 Released
Solved Problem after installing K60 RC3 on Joomla 4.1.4
4 years 2 months ago - 4 years 2 months ago #223231
by jeankhan
Problem after installing K60 RC3 on Joomla 4.1.4 was created by jeankhan
Hi. Just done a fresh install of a Joomla 4.1.4 on my localhost.
Then I installed Kunena 6.0.0 RC3.
Now I get the message Table kunena_configuration doesn't exist in any page of the administration side.
The site is unusable. Luckily is only for test, I am still waiting for a stable version of Kunena.
Last edit: 4 years 2 months ago by jeankhan.
4 years 2 months ago #223233
by Leen
With kind regards
Leen
Replied by Leen on topic Problem after installing K60 RC3 on Joomla 4.1.4
Hello.
did you also install the sample data and menu of kunena ?
and your localhost is that locally on your pc with eg xampp or wamp server ?
you could also download the Nightly Builds that is now also available to be able to try
With kind regards
Leen
4 years 2 months ago #223250
by jeankhan
Replied by jeankhan on topic Problem after installing K60 RC3 on Joomla 4.1.4
No, I have installed no samples nor menu. Where I can find docs about this?
I use my own pc (Win) as local server for all Joomla test. Laragon, not XAMPP.
Thx for answer
Thx for answer
4 years 2 months ago #223255
by jeankhan
Found samples.
Installed menu, updated kunena to nightly build (rc4)
Now kunena is working.
Time to create page: 0.233 seconds
