Question Problem with avatar upload and preview post
6 years 1 month ago #214182 by kunenauser40
Hi to all,
I have lastest Joomla (3.9.21) and latest kunena (5.1.19) installed.
I haven't noticed exactly when (but I'm sure 2-3 months ago there wasn't any problem), but I see that the preview post is not working (it displays blank grey page).
Also I received message from users that they cannot upload avatar, they browse for the avatar, they press "upload" and the default grey head avatar is still there always.
I searched for solution here, I changed in the configuration - Avatars the option "Default avatar type" from icon to image but still the same.
Also I noticed that if I select an avatar from the gallery of kunena instead of upload a new one, then it works, but if I try to do it from the "upload" option in my profile then it doesn't work so the users can only select an avatar from my gallery of kunena (I have uploaded some avatars myself if any user prefer these)
This is my configuration report if you can find what causes these 2 problems (preview post and avatar upload).
Thank you.
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: 4/30/2012
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.19 | creationdate: 2020-08-15
Kunena template params:
Kunena version detailed: Kunena 5.1.19 | 2020-08-15 [ Tethys ]
Third-party components: UddeIM 4.0
Plugins: Search - Kunena Search 5.1.2
Modules: Kunena Latest 5.1.2
6 years 1 month ago #214183 by rich
Yes, that's two known bugs. The avatar upload you can solve the problem for now, if you allow direct component access (Configuration -> tab General -> Direct Component Access = Yes).
For the second bug "preview" I have unfortunately no solution at the moment.
