Question Problems with .pdf
8 years 3 months ago - 8 years 3 months ago #202894 by unker
Problems with .pdf was created by unker
Hi there,
I'v posted this topic also in "German" section, but may my chance to get a solution is higher if I make it readable for all :)
die integration of .pdf caused problems in v_5.1.2:
and if I click on the .pdf-icon I get this:
My configuration:
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : jsn_epic_pro | author: JoomlaShine.com | version: 6.2.3 | creationdate: 12/23/2017
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.2 | creationdate: 2018-07-15
Kunena template params:
Kunena version detailed: Kunena 5.1.2 | 2018-07-15 [ Charon ]
Third-party components: UddeIM 4.0
Plugins: None
In addition to this I got to know from users that the entire post is unreadable when using iphone/ipad with Safari.
Ich hope, somebody knows a solution.
Viele Grüße
Hartmut
Last edit: 8 years 3 months ago by unker.
8 years 3 months ago #202896 by 810
Replied by 810 on topic Problems with .pdf
Hi, the icon issue is a know issue, we are working for a fix for it. For the main issue. Safari has no build-in support for pdf.
So you need a plugin like adobe pdf or other plugin.
See more info: www.cnet.com/news/pdfs-not-showing-in-safari/
8 years 3 months ago #202905 by unker
Replied by unker on topic Problems with .pdf
Thanks for reply, 810 :)
But the first two pictures are not from Safari, but from Firefox in a Windows system.
Only the last picture was a sceenshot from an ipad.
Best Regards
Hartmut
8 years 3 months ago #202911 by 810
Yeah more modern browser are going to remove the pdf's.
But you need to do the same, install a plugin.
8 years 3 months ago #202914 by unker
Hi 810,
this seems to be not really logical to me.
With v_5.0.14 everything is still fine, which means that the problem should be not caused by the browser, but has to do with Kunena_v_5.1.2.
On my live site 5.0.14 is active and I do not have this "This browser does not support PDFs. Please download the PDF to view it: Download PDF. " and also by clicking the icon I do not have the modal popup. All is fine.
Only v_5.1.2 has this problem.
Any other idea? :)
8 years 3 months ago - 8 years 3 months ago #203885 by unker
My browser (Firefox v61.0.2) does open .pdf without any problems (plugin enabled) on any page, also here, but in my forum not.
So I have to investigate further... :-(
Does anyone has an idea?
Time to create page: 0.175 seconds
