- Thank you received: 5
Question Too many problems with 5.1.1 need to downgrade asap.
Is not working with most templates,
discuss is not working (i tried the fix),
my mistake that updated with out to try it first, but now i need help to downgrade.
Rendering Error in layout Widget/Login/Logout: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '}' at line 1. Please enable debug mode for more information.
Note that guests who are not logged-in, see the forum acting normally.
So, I downloaded Kunena 5.0.14, installed it, and the problem is gone, at least for right now.
The worst thing is that there is not real support, there is the support from volunteers ,
but is not professional support like to open ticket with problem and ask for help.
I cant be sitting here for days waiting for one reply.
If you know what migration solutions exist please advice.
pintobuck did you just installed the 5.0.14 over 5.1.1 ?
- Thank you received: 2545
You can install K 5.0 over it. That's no problem. But it needs a database correction. AIM has ended the service end of 2017, therefore the column AIM has been removed from Kunena 5.1.pintobuck did you just installed the 5.0.14 over 5.1.1 ?
You need this correction after downgrade, otherwise users cannot edit their profile.
#__ is your database prefix
