Kunena 7.0.8 Released
Solved Forum Link does not work after update to Kunena 5.1.
8 years 3 months ago #199737 by mibert
Hi there,
after updating to K5.1. I realized that the Forum Index Link does not work anymore.
It links to www.mysite.de/index.php?Itemid=940 which returns a 404 Error.
Anyone is facing same issue and have a solution?
Thanks in advance for your advise.
Best regards
Michael
8 years 3 months ago #199744 by rich
Please add a Configuration Report .
8 years 3 months ago #199745 by mibert
Sorry, here you go:
htaccess: Exists | PHP environment: Max execution time: 600 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : yoo_nano3 | author: YOOtheme | version: 1.0.16 | creationdate: May 2015
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.0.5 | creationdate: 2018-02-11
Kunena template params:
Kunena version detailed: Kunena 5.1.0 | 2018-05-13 [ Ariel ]
Third-party components: CommunityBuilder 2.1.4 | UddeIM 4.0
Plugins: Search - Kunena Search 5.1.0 | Content - Kunena Discuss 5.1.0
Modules: Kunena Latest 5.1.0 | Kunena Stats 5.1.0
8 years 3 months ago #199750 by rich
This is a wrong menu item.
89 Mitgliederforum newmain view=category&catid=504 gemeinschaft-alle-fuer-einen-einer-fuer-alle57/mitgliederbereich21/mitgliederforum-mitglieder-bereich-89
Please make following:
1. Create in the Kunena menu a menu item "Menu Item Type = Show Category" and select the category which is selected in your wrong menu item. (If you no want to show this tab in the forum, then choose on tab Link Type "Display in Menu = No")
2. Change the wrong menu item in newmain to Menu Item Alias ( see image here ).
Then empty the chache and test your forum.
8 years 3 months ago #199751 by mibert
Hi Rich,
thanks for the kind advise.
I have tried, but it did not solve the problem.
You may have a look at below link:
If you click in "Forum Startseite", you will end up at a 404 page.
Best regards
Michael
8 years 3 months ago #199752 by rich
You have still wrong menu items which are not listed in your configuration report. Are the menu items with the itemid 940 and itemid 902. The forum will called via this wrong menu items, therefore the error.
This link you have posted. The itemid is wrong (red).
yourwebsite/index.php?option=com_kunena&view=topic&catid=7&id=77227&Itemid=902&limitstart=80#108687
Click on your posted link and change in the browser address the itemid (blue) and you see the tabs and also the breadcrumbs are correct.
yourwebsite/index.php?option=com_kunena&view=topic&catid=7&id=77227&Itemid=2592&limitstart=80#108687
You must repair this menu items. Links of other menus, which are linked to the forum, must be Menu Item Type = Menu Item Alias
