Solved Errors click titles in Forum after Update Joomla and Kunena
8 years 4 months ago #199482 by michaelg
Dear all,
there is a problem with my Forum after updating today noon. After Update Joomla to latest version and Kunena Forum I
clear the cache. But I got errors clicking categories and postings.
eg:
mccforum.de/index.php/mcc-forum6/534-tip...-r%C3%BCckruf/unread
mccforum.de/index.php/mcc-forum6/3-ausst...mbiinstrument/unread
I can´t find the reason why this happens...
Best regards
Michael
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 256M | Max file upload: 8M
Joomla default template details : ol_consen | author: olwebdesign.com | version: 3.5.0 | creationdate: 2016
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.0 | creationdate: 2018-05-13
Kunena template params:
Kunena version detailed: Kunena 5.1.0 | 2018-05-13 [ Ariel ]
Third-party components: CommunityBuilder 2.1.4 | UddeIM 3.9
Plugins: None
8 years 4 months ago #199488 by 810
your kunena menu items are not correct, please go to backend - kunena - tools - menu - restore kunena menu
8 years 4 months ago #199493 by michaelg
thanks for this hint, but it only works partially. Now I have the correct menue inside the forum, but
to categories and single articles are still not useable. Error 404 (Component not found ???)
Best regards
Michael
8 years 4 months ago #199495 by 810
if you can create a super account for me, then i will check it . use [*confidential] [/confidential] tags without the *
8 years 4 months ago #199503 by michaelg
Okay I will do.
8 years 4 months ago #199510 by 810
ok fixed.
The issue was wrong menu items, you should use system aliassen on the main menu.
The following user(s) said Thank You: michaelg
Time to create page: 0.220 seconds
