Question Kunena 5.0.2 and Crypsisb3 problem on Message title length!!! HELP
10 years 1 month ago #180336 by abustone1
Hello there, I have updated our Kunena to 5.0.2 and installed the new template Crypsisb3 but if you change the title length nothing happen, so its showing all the title length. see screenshots
Please help as soon as you can!
Will wait an answer from you! thanks
10 years 1 month ago #180346 by rich
This topic on your image is from 26.10.2015. This setting has no effect on already exitss topics. It prevents the input of long title in the editor only.
10 years 1 month ago #180348 by abustone1
Hi rich, I get it, is there any way to change the old topics by change some php codes?
10 years 1 month ago #180363 by 810
10 years 1 month ago #180369 by abustone1
Super please let me know when its updated also the status after login its offline by default and if you change to busy the image color changed but the status text not changing same when writing status text when entering text its not coming. Anyway Kunena is awesome
10 years 1 month ago #180371 by 810
that's a joomla bug, will be fixed on next update
