Question Problem with emoticons 5.0.0-RC3
9 years 10 months ago #176826 by ForumLeasing24
When I want to insert a emoticon, the board is in the background. The brain does not choose any emotcon.
9 years 10 months ago #176912 by Josh
Link please so that we can try to replicate. Also what version of IE are you using?
9 years 10 months ago #176919 by 810
this is a local joomla template issue.
If you switch back to protostar for the moment, you will see the correct modals.
You need to check the css properties on modal. (z-index is set wrong)
9 years 10 months ago #176934 by ForumLeasing24
Whether to modify the z-index in css template epis-pro side or css template Crypsis of Kunena? Which is exactly the file and the value z-index?
Thx.
Ps.
My website: forumleasing24.pl/forum/nowy-temat
9 years 10 months ago #176935 by ForumLeasing24
The problem occurs on all browsers.
9 years 10 months ago #176936 by ForumLeasing24
Time to create page: 0.264 seconds
