Solved Category and topics title render problem
9 years 3 months ago #194432 by geoffroy
Hello everybody, i have some issues since i upgraded from Kunena 3.x with my titles of category and topics, you can see the result below.
I was thinking about a Kunena template issue, but every Template is having the same behavior.
Thx for your ansers, and if u got the same issue.
9 years 3 months ago #194443 by rich
You have this issue also with the Joomla default templtate Protostar?
9 years 3 months ago #194446 by geoffroy
Yeah have it with all Template of Joomla and Kunena, combinations tests below :
* protostar + clean
* protostar + Crypsis
* protostar + Crypsisb3
I was thinking reimporting my category table ... any suggestion ?
9 years 3 months ago #194448 by geoffroy
Here is the source of th e category title when rendered :
<h1 class="heading-style-1 visible-first"><a href="/joomla3/index.php/forum?view=category&amp;catid=11" title="Consulter la catégorie '<span class=" item_title_part_0="" item_title_part_odd="" item_title_part_first_half="" item_title_part_first="" item_title_part_last"="">Divers'" rel="nofollow"&gt;<span class="item_title_part_0 item_title_part_odd item_title_part_first_half item_title_part_first item_title_part_last">Divers</span></a></h1>
it seems there is a span in the title of title attribute.
9 years 3 months ago #194450 by rich
Have you installed a tool which compress scripts or a SEO component? The classes of your source code does not exists in kunena.
The source of k.org
<h1> <a href="/forum/94-Kunena---To-Speak" title="View Category 'Kunena - To Speak!'" class="hasTooltip" rel="nofollow">Kunena - To Speak!</a> <small class="hidden-phone nowrap"> (107 topics) </small> </h1>
9 years 3 months ago #194461 by geoffroy
Im going to check my plugins. Additional info : i installed a TemplateMonster template, using bootstrap, do you know if this one may use those kind of tools ?
