Solved no posts headers after upgrade to 5.0.7
- Thank you received: 2545
@sgames, did this solve your problem?rich wrote: Install Kunena again then empty the cache.
In components/com_kunena/template/crypsis/layouts/message/item/default.php replace this:
Edit: The topic history has the same issue so in components/com_kunena/template/crypsis/layouts/topic/edit/history.php replace this:
