Kunena 7.0.8 Released
Question Link problem with Latest Topics module
10 years 10 months ago #169749 by knoakes
I have a Kunena install in my joomla 2.54 site.
I also have installed the latest module and tried every setting I can see but the links are not the same as they are if I go directly into the forum category.
The working link from the forum category would be..
www.airportcustomer.com/forum/cuss/89-fgfggf
The link to the same item from the latest module would appear as...
www.airportcustomer.com/cuss/89-fgfggf#72
I have tried every combination of SEO setting in joomla and kunena.
Ass you can see the /forum part of the path is being omitted.
Does anyone have any ideas. I could probably write an htaccess rule to redirect it but there is probably a proper solution.
Many thanks!
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 105M
Joomla default template details : paradigm_shift | author: Shape5.com | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.6 | creationdate: 2015-09-28
Kunena version detailed: Kunena 4.0.6 | 2015-09-28 [ Pielungo ]
Plugins: None
Modules: Kunena Latest 3.1.1.1
10 years 10 months ago #169757 by sozzled
knoakes wrote: I have a Kunena install in my joomla 2.54 site.
I do not understand "Joomla 2.54" Do you mean J! 2.5.4?
10 years 10 months ago #169760 by knoakes
Yes sorry I did mean j! 2.5.4 but acctually I got it more wrong it should be...
Joomla! version: 2.5.28.
10 years 10 months ago - 10 years 10 months ago #169764 by sozzled
I do not know how to help you with this. This website here uses J! 2.5.28 and the Kunena Latest module works here (I do not know if the version here is version KL 3.1.1.1, however). This suggests to me that you have a routing issue peculiar to your website, probably caused by a badly constructed menu.
I am guessing that the link problem with the Kunena Latest module is not a problem with the module; I am guessing that the problem lies with your Joomla menu.
For me, the simplest starting-off point would be to use the "trash-burn-build principle" . See also Kunena menu issues .
I hope this helps.
Last edit: 10 years 10 months ago by sozzled.
10 years 10 months ago #169766 by 810
Yes, this is caused by a bad menu.
try to recreate the menu, then check again. If its works, then rename the menu item, not removing them.
10 years 10 months ago #169775 by knoakes
You mean a joomla menu?
Time to create page: 0.254 seconds
