Question Latest Posts Module - Link to Forum does not work properly
3 years 5 months ago - 3 years 5 months ago #228386 by Petley
Hello
On the latest posts module , if you click a post and then try to reply , it gives an error message
If you go directly to theforum and then reply to the same post , its OK
I have had to disable the latest posts module :-(
Any ideas
Terry
PS It may be because I am using a paid template NTS Kay
Last edit: 3 years 5 months ago by Petley.
3 years 5 months ago #228389 by 9themestore
Hi Terry,
If the appear on our template, please create new topic on our forum. We will debug and solve this issue.
Regards,
