Question Problems with Default Avatars in Kunena 6.0.1.1
4 years 3 months ago - 4 years 3 months ago #224300
by purezen
Problems with Default Avatars in Kunena 6.0.1.1 was created by purezen
Hello Support
I'm reasonably confident there are problems with the display of Customized Default Avatars in Kunena 6.0.1.1
Before posting this message, I made sure to test all combinations of Joomla 4 and Kunena 6 templates - same problem occurs with the Aurelia template.
I do use a custom Kunena template from 9themestore.
1. Custom Default Avatar Image not showing in Kunena 6.0.1.1 - I have custom default images uploaded.
In the frontend of Kunena, a tiny .SVG image is showing instead.
My Settings in Kunena backend are:
Configuration / Avatars.
Default avatar Type = Image
I already had custom avatars uploaded from my Kunena 5 install and checked to see custom images were imported into the Kunena 6 install - they are all there.
2. The second problem is the size of the default avatar image - it's very, very small.
Screen shot showing small and incorrect avatar.
I am also aware of bugs with my custom 9themestore template, which I'm working on right now, but I don't believe they are the cause of this problem.
From this page: www.moviestudiozen.com/forum/vegas-pro/3...otal-bitrate-setting
For a comparison, this is how my Custom Default Avatar used to display on the Kunena 5 forum (Joomla 3).
I have a hidden copy of my old website and forum located here:
www.moviestudiozen.com/msz_test3/forum/v...otal-bitrate-setting
Custom Default Avatar image url was this:
www.moviestudiozen.com/msz_test3/media/k.../nts_kay/nophoto.png
Regards
Derek
Regards
Derek
Last edit: 4 years 3 months ago by purezen.
4 years 3 months ago #224305
by Leen
With kind regards
Leen
Replied by Leen on topic Problems with Default Avatars in Kunena 6.0.1.1
have you also tested various settings at e.g. Template : Aurelia > tab Features
and also at the avatar tab you can change size
With kind regards
Leen
- Thank you received: 2545
4 years 3 months ago #224316
by rich
Replied by rich on topic Problems with Default Avatars in Kunena 6.0.1.1
Confirmed, it's not possile to use a "nophoto" image. I will create a bug ticket.
The following user(s) said Thank You: purezen
