Question Message body editor missing
5 years 7 months ago #216110 by ronlevine
Good morning everyone,
I have installed Kunena with both Blue Eagle5 and the "remove powered by" plugin and template.
I am using JCE Pro for my default editor on the site. I have tried switching to one of the default joomla editors with no change in the issue.
When I go to try to post on the forums, I get the area where I can put the title of the post in, but the editor area where I would put the body of the post in simply doesn't show. Is this a setting somewhere that I don't know about? I am a Superadmin on my site so permissions should not be an issue.
With regards,
Ron
5 years 7 months ago #216111 by rich
Replied by rich on topic Message body editor missing
I'm sorry, but you can't use Joomla editors with Kunena. Kunena uses BBCodes (CKEditor) not HTML editors.
When this editor isn't available, you must exclude the ckeditor.js from your page optimization.
Path: /media/kunena/core/js/ckeditor.js
www.kunena.org/bugs/know-bugs
5 years 7 months ago #216112 by ronlevine
Is the BBCodes editor loaded by default?
I just have the JCE editor set as the default for joomla. I assumed, probably incorrectly, that it would just populate across to Kunena.
5 years 7 months ago #216113 by rich
Yes, also if you select another editor, it has no effect and it loads the CKEditor.
5 years 7 months ago #216114 by ronlevine
Ok, it appears that the forums are not actually loading the editor. Any ideas on why that might be?
Thank you for your help.
5 years 7 months ago #216115 by rich
As I wrote earlier, this happens when a page optimization is active.
