Question Various issues with K5.2 and K5.2.1
5 years 10 months ago #214849 by btc
Configuration report is at the end - this is a development version of the website.
I've tried by 5.2.0 and 5.2.1 but there are three problems:
  1. Can't hide any of the buttons using Blue Eagle or Crypsis - and they take up an inordinate amount of space on a mobile screen (360px). I thought hiding the buttons was one of the 5.2.1 changes.
  2. The quote function is unusable - it just needs the cursor to be automatically placed under and outside the blockquote element and it will be a great improvement on how quote works on 5.1.
  3. The video button doesn't seem to work - I enter a YouTube url, but nothing is displayed. (just entering a youtube url without the button does work)
Until 1 and 2 are fixed I would prefer to stick with 5.1. But if and when they are, 5.2 will be an improvement.
htaccess: Exists | PHP environment: Max execution time: 50 seconds | Max execution memory: 2147483648 | Max file upload: 256M
Joomla default template details : business_pro | author: Shape5.com | version: 1.0 | creationdate: August 2013
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.6.0 | creationdate: 2020-12-16
Kunena template params:
Kunena version detailed: Kunena 5.2.1 | 2020-12-27 [ Hebe ]
Third-party components: CommunityBuilder 2.4.7
Plugins: Search - Kunena Search 5.1.2 | Content - Kunena Discuss 5.1.2
Modules: Kunena Latest 5.1.2 | Kunena Search 5.1.2
5 years 10 months ago - 5 years 10 months ago #214859 by ruud
I can confirm issue 1 and 2: unworkable on mobile.
This is also holding me back from upgrading.
Also wondering what version of CKEditor is used because when I look at the CKEditor website for version 5, on the demo pages it is perfect on mobile but looks very diffrent from the version that is implemented in Kunena 5.2.1
sharing = caring
Last edit: 5 years 10 months ago by ruud.
5 years 10 months ago - 5 years 10 months ago #214860 by xillibit
We are using CKeditor in version 4.x to have the bbcode plugin (which needs to be improved by the way :( and doesn't exist in version 5.x of CKeditor)... There are different skins available for CKeditor 4 : ckeditor.com/cke4/addons/skins/all?sort_...ort_order=ASC&page=0
Last edit: 5 years 10 months ago by xillibit.
5 years 10 months ago #214863 by ruud
Thanks @Xillibit!
Sorry for hijacking your topic @btc :)
On mobile the buttons area is not only to large, but there are also buttons that you would probably never use on a mobile device.
As all buttons (and template) are 'compiled' into the ckeditor.js there is no way to have a different set of buttons for desktop and mobile other then use two ckeditor.js files.
But you can remove buttons dynamically with JavaScript (untested). So it would be possible to have a JavaScript running that detect the view width and based on that removes a bunch of buttons
CKEDITOR.config.removePlugins = 'Save,Print,Preview,Find,About,Maximize,ShowBlocks';
sharing = caring
5 years 10 months ago #214865 by xillibit
You can use a different skin without touching the ckeditor.js by adding this line in the file ckeditor_config.js and you should copy your skin into /media/kunena/core/js/skins :
config.skin = 'moono-lisa';
5 years 10 months ago #214866 by ruud
Thanks @Xillibit, better now :)
sharing = caring
Time to create page: 0.195 seconds
