Solved Kunena Login Button - Remember Me does not work
2 years 11 months ago #229787 by Goldie
I noticed another bug. If users login via login button in Kunena Menu and click on "Remember Me" it will not set Remember Cookie. If they use Joomla Login Module it will work.
2 years 11 months ago - 2 years 11 months ago #229808 by Gindi
I have also logged in multiple times using the Kunena login and can confirm this error.
The same error also exists here in the forum at kunena.org.
gindi
Last edit: 2 years 11 months ago by Gindi. Reason: Zusatz
2 years 10 months ago - 2 years 10 months ago #230278 by Pinkeltje
Same here. Is there already a solution?
Last edit: 2 years 10 months ago by Pinkeltje.
2 years 10 months ago #230281 by Goldie
in current Kunena version it works. I just happened to notice one day that it was fixed.
2 years 10 months ago - 2 years 10 months ago #230282 by Pinkeltje
Are you using a custom template? In this forum it still doesn't work. When inspection cookies there is no remember me cookie.
Cookies when using in in this site via Menu-item User
Cookies when using forum login
2 years 10 months ago #230293 by rich
Thank you, I will add it to our bug list.
The following user(s) said Thank You: Ratman, Pinkeltje
