Solved moderate post not working
4 years 1 month ago #224818 by olizan
I have some trouble to moderate some post
Impossible to move post to another place for the first and quick reply post.
When i post with "reply" button, it works.
Do you have an issue ?
Olivier
first and quick
reply bouton
4 years 1 month ago #224822 by rich
Replied by rich on topic moderate post not working
I cannot reproduce this error. Which template are you using? It doesn't seem to be Crypsis. Does this error also occur with the Kunena default template?
Please enable debug mode (Confiuration -> tab General) to get a more accurate error message.
Also create a configuration report.
4 years 1 month ago - 4 years 1 month ago #224823 by olizan
Replied by olizan on topic moderate post not working
Kunena : 5.2.9
Template : crypsisb3 5.2.9
same error with crypsis
Rendering Error in layout Topic/Moderate: Missing format specifier at end of string in .../components/com_kunena/template/crypsisb3/layouts/topic/moderate/default.php on line 196
Layout was rendered in .../components/com_kunena/template/crypsisb3/pages/topic/moderate/default.php on line 46
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 16M
Joomla default template details : jd_miami | author: www.joomdev.com | version: 2.2 | creationdate: 18 January 2018
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.2.9 | creationdate: 2022-06-08
Kunena template params:
Kunena version detailed: Kunena 5.2.9 | 2022-06-08 [ Catraia ]
Plugins: None
Last edit: 4 years 1 month ago by olizan.
4 years 1 month ago #224851 by rich
First repair the two menu items (marked red in the image).
1. The menu item in the main menu must be a Menu Item Type = Menu Item Alias ( see here ).
2. the first menu item "Forum" in the Kunena menu is linked to itself. Open this and select the index as the target.  Menu Tips
3. then empty the cache
4. go to the Kunena Tools and recount the statistics.
Then try to moderate a post.
4 years 1 month ago #224895 by olizan
Hello and thks for your reply.
1. The errors still there after your procedure.
2. I have recreate the kunena menu
3. delete all forum submenu
4. empty cache
error still there
4 years 1 month ago #224896 by olizan
But i don't understant why i can moderate post i create and i can't moderate post with "quick reply".
Time to create page: 0.162 seconds
