Question Search does not work, it shows old topics and does not search by username
4 years 9 months ago - 4 years 9 months ago #221059 by Kotsolis
1) Search functionality doesn't work in my site. It shows forum topics up to November 2021 but not after that date:
www.gameworld.gr/forum/search?searchuser...te=all&childforums=1
2) * Also you should skip the first 5 results in that link. The username is "Manos" . For an unknown reason, over the last months I see full names of users instead of usernames in the posts. And the same problem exists in search function. So when I type a username (ex "Manos") then it not only shows results of that user, but it also shows users that have "Manos" inside their full name!
Probably, starting from November (unfortunately I might upgraded to the latest Kunena version back then), the Forum counts only full names and not usernames.
Kunena v.5.2.6 . Also make sure that this is fixed in a later version because you tell me to upgrade.
Last edit: 4 years 9 months ago by Kotsolis.
  • rich
  • rich's Avatar
  • Away
  • Kunena Moderator
  • Kunena Moderator
  • I like sunshine and flowers
4 years 9 months ago #221075 by rich
Go to Dashboard -> Tools
Synchronize the users (mark the checkbox "Update user names in messages") and let recount also the statistics. Maybe it helps.
4 years 9 months ago #221080 by Kotsolis
What do I click here? Only the first box is checked.
  • rich
  • rich's Avatar
  • Away
  • Kunena Moderator
  • Kunena Moderator
4 years 9 months ago #221111 by rich
Mark these two checkboxes.
4 years 9 months ago #221119 by Kotsolis
I did it and then I clicked Sync.
Nothing changed. And the 3rd box was also reverted. Is this normal?
Also in the Forum, even though I cleared cache, I still see full names instead of usernames!
4 years 9 months ago #221128 by Kotsolis
JomSocial . Configuration > Layout > Display Name -> Username
Solved.
Thank you.
