Solved User full name fix when quoting does not work for existing posts
4 years 10 months ago #220529 by btc
HI,
I've installed 5.2.7 on a new copy of my website for testing purposes (the production database is still on 5.1). When testing the quote function, the full name of the user who has been quoted is shown correctly, which wasn't so with 5.2.6.. However, existing posts that have quotes still show only the first name. This happens using both Blue Eagle 5 and Crypsis.
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 2147483648 | Max file upload: 256M
Joomla default template details : business_pro | author: Shape5.com | version: 1.0 | creationdate: August 2013
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.6.6 | creationdate: 2021-07-25
Kunena template params:
Kunena version detailed: Kunena 5.2.7 | 2021-12-04 [ Morella ]
Third-party components: CommunityBuilder 2.6.4
Plugins: Search - Kunena Search 5.2.2 | Content - Kunena Discuss 5.2.2
Modules: Kunena Latest 5.2.2 | Kunena Search 5.1.2
4 years 10 months ago #220534 by xillibit
Thanks for the report i will take a look
4 years 10 months ago #220538 by rich
Maybe it helps, if you recount the statistics (Dashboard -> Tools)..
4 years 10 months ago #220539 by btc
Thanks for the suggestion, which I tried but didn't work.
4 years 10 months ago #220541 by btc
I've just noticed another issue with quotes. The hyperlink just goes to the website root when the a post has been quoted after conversion to K5.2.7. Quotes that were done previously, ie when K5.1 was still used, have only the first name but do have the full path to the post that's been quoted.
4 years 10 months ago #220689 by xillibit
On Kunena 5.1.19 which Kunena template are-you using ? And which editor type (BBcode or wysibb) do-you have ?
I tried to do couple of quotes on Kunena 5.1.19 then updated to Kunena 5.2.7, but i don't see your issue :
Time to create page: 0.184 seconds
