- Thank you received: 187
Solved No icons
my example is from Joomla! 3.10.4 with the shaper_helixultimate - Default template and Kunena Version: 5.2.8
With kind regards
Leen
Only Font Awesome. But no icons Font Awesome displayed anywhere. Not sure it's a problem for me.
The changelog of Kunena 5.2.8 contains :
Bug fix : Fixed icons disappearing in Kunena 5.2.7 (#8634)
My Joomla is also 3.10.4.
got that from here when you click on start using this icon the correct code comes up
sample icoon code
With kind regards
Leen
If I install a lempate eg Phoca POS as a test and set it up a bit, I can see the icons.
so i think it would be wiser to look for another template
With kind regards
Leen
After my last update of Kunena, I entered a wrong Font Awesome code.
Problem solved. Thanks for your help.
