Solved No icons
- Thank you received: 2544
You have nothing overlooked, this option does not exist. We don't have a template in Kunena 5.2 that works with Joomla bootstrap 5 templates.sorry maybe i'm overlooking it but i really can't find the option for bootstrap 3 in crypsisb4.
This is only available for Joomla 4.0 and Kunena 6.0, but there is no stable version of Kunena 6.0 yet.
The combination Joomla 3.10 with bootstrap 5 template and Kunna 5.2 does not work, unless you find a third party Kunena template which is b5 compatible.
my example is from Joomla! 3.10.4 with the shaper_helixultimate - Default template and Kunena Version: 5.2.8
With kind regards
Leen
Only Font Awesome. But no icons Font Awesome displayed anywhere. Not sure it's a problem for me.
The changelog of Kunena 5.2.8 contains :
Bug fix : Fixed icons disappearing in Kunena 5.2.7 (#8634)
My Joomla is also 3.10.4.
got that from here when you click on start using this icon the correct code comes up
sample icoon code
With kind regards
Leen
