- Thank you received: 1
Kunena 6.4.8 Released
Solved Bug in [code]...[/code] parser
- joomlaworks
Which means that there is still a bug in the BBCode parser which transforms \[code\]...\[/code\] saved in the database to <pre> HTML tags in the frontend.
Case in point: www.joomlaworks.net/forum/simple-rss-fee...d-loading-xml#178176
That post is 4 months+ old, I upgraded to Kunena v5.2.5 less than a month ago.
* I'm adding backslashes to the BBCode examples above as they break when rendering in this forum as well...
- joomlaworks
- joomlaworks
Is there at least a handy/smart way to disable BBCode parsing altogether?
- joomlaworks
A PR has been submitted with the (simple) fix here: github dot com/Kunena/Kunena-Forum/pull/8877
- joomlaworks
The fix is merged nowThe issue persists in newer releases.
