Solved Problem with notification e-mails
5 years 8 months ago #216302 by Daviciacus
Ever since I recently updated to the latest version of Kunena, there is an issue with the notification e-mails. The "Posted by" line gives this every time:
Posted by : {KunenaFactory::getProfile()->getProfileName(KunenaUser, '???', false)}
This worked fine before the update. I had already done "Synchronize users" after the update too.
Please let me know how to fix this.
On the forum pages on the site itself everything seems to work fine, after working around other issues (the forum menu display) which I reported here days ago but were never responded to.
Thanks.
5 years 8 months ago #216304 by Daviciacus
A small update: the issue appears in the non-html version of the notification emails (of new posts/topics). When I switch to the html version of the notification email, the name of the one who made the post is shown correctly.
5 years 8 months ago - 5 years 8 months ago #216305 by xillibit
In the file /components/com_kunena/template/crypsis/layouts/email/subscription/default.php line 245 add :
$profilename = KunenaFactory::getProfile()->getProfileName($author, '???', false);
always in the same file at line 265 now replace this :
{$this->text('COM_KUNENA_VIEW_POSTED')} : {KunenaFactory::getProfile()->getProfileName($author, '???', false)}
by :
{$this->text('COM_KUNENA_VIEW_POSTED')} : {$profilename}
You can do too the same changes in the file : /components/com_kunena/template/crypsis/layouts/email/subscription/moderator.php
Last edit: 5 years 8 months ago by xillibit.
5 years 8 months ago #216307 by Daviciacus
modificationThanks for the fast response.
Will this code modification be implemented in the next version/update of Kunena?
5 years 8 months ago #216308 by xillibit
Because of this issue : github.com/Kunena/Kunena-Forum/issues/7947 , i have already changed it in the developpement version of Kunena
5 years 8 months ago #216309 by Daviciacus
Thanks! Then I will just wait until the next update, since at least it works fine on the html email version.
