Solved Problem loading CK Editor / Kunena 5.2.2 / Crypsisb4
5 years 8 months ago #215756 by swillig
Hi there,
I have a problem with Kunena 5.2.2 / Joomla 3.9.24 and the Crypsisb4 Template and the ckeditor.
If i want to start a new topic, the ckeditor does not load an on debugging console I get the following error:
ckeditor.js:547 Uncaught TypeError: Cannot read property 'split' of undefined     at Object.loadPart (ckeditor.js:547)     at l (ckeditor.js:284)     at a.<anonymous> (ckeditor.js:283)     at a.l (ckeditor.js:10)     at a.<anonymous> (ckeditor.js:12)     at a.CKEDITOR.editor.CKEDITOR.editor.fire (ckeditor.js:13)     at a.fireOnce (ckeditor.js:12)     at a.CKEDITOR.editor.CKEDITOR.editor.fireOnce (ckeditor.js:13)     at k (ckeditor.js:281)     at Object.<anonymous> (ckeditor.js:281)
I assume that there is a conflict, but I don't get with wat.
There are no modules loaded, which do any other javascript except of the joomla core plugins/modules/header.
Here is my config report:
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 1000M | Max file upload: 10000M
Joomla default template details : VFT 2018 | author: S. Willig | REIKEM | version: 1.0.0 | creationdate: Oct 2018
Kunena default template details : Crypsisb4 | author: Kunena Team | version: 5.2.1 | creationdate: 2020-12-27
Kunena template params:
Kunena version detailed: Kunena 5.2.2 | 2021-01-13 [ Iris ]
Plugins: None
The Forum is private so I cannot give public access to this.
Has anyone an idea what I can do?
5 years 8 months ago #215762 by rich
Exclude the file /media/kunena/core/js/ckeditor.js from your page optimization.
5 years 8 months ago #215767 by swillig
Thank you for your quick reply.
There is no page optimization (tool) active or installed.
Caching mode in Joomla is disabled.
The only thing - gzip was endabled, but disabling makes no difference.
Any other idea?
5 years 8 months ago - 5 years 8 months ago #215768 by xillibit
Do-you checked in your Joomla! template if there are options for optimize JS ?
Last edit: 5 years 8 months ago by xillibit.
5 years 8 months ago #215769 by swillig
thanks for your reply.
It's a template written by myself and there is noch JS optimizing.
I'm loading jQuery (3.3.1 min) and Bootstrap (4.1.1) in the template.
Here is the link to v-f-t.de/media/kunena/core/js/ckeditor.js - and this is how it's loaded.
5 years 8 months ago #215779 by rich
Is your forum correctly installed? The configuration report shows Kunena 5.2.2 but Crypsisb4 v 5.2.1
It should be the same version 5.2.2
Time to create page: 0.167 seconds
