Solved 5.2.1 Editor not displaying for Reply and Edit
5 years 9 months ago #215026 by RadioSteve
Hello, I updated to 5.2.1 and the new editor appears for new topics, but when replying or editing a post the editor does not load. Instead it appears as follows:
Does anybody know why this might be happening?
5 years 9 months ago #215038 by xillibit
Which Kunena template are-you using ? When the editor doesn't be laoded can-you look into the developpement console of your browser into javascript tab if you have some errors ?
The following user(s) said Thank You: RadioSteve
5 years 9 months ago #215043 by RadioSteve
I do see an error where the editor does not load. This error also occurs on the topic page itself (before trying to open the reply editor), but not when creating a new topic, where the editor loads correctly, and not on other pages such as the topic list or index.
The template is Orion Pro.
5 years 9 months ago #215058 by xillibit
RadioSteve wrote: I do see an error where the editor does not load. This error also occurs on the topic page itself (before trying to open the reply editor), but not when creating a new topic, where the editor loads correctly, and not on other pages such as the topic list or index.
Are-you using script merger plugin ?
RadioSteve wrote: The template is Orion Pro.
I didn't mean the Joomla! template, but the Kunena template
5 years 9 months ago #215061 by RadioSteve
Two Kunena plugins are enabled...the Kunena & Joomla Integration plugins. (At the Joomla! level there is Core Design Scriptegrator, which I tried disabling to no effect.)
The Kunena template is Crypsis.
5 years 9 months ago #215114 by RadioSteve
Fixing the jQuery error solved the problem. Thank you for bringing it to light @xillibit
Time to create page: 0.150 seconds
