Solved New editor does not allow right-click Paste
5 years 9 months ago - 5 years 9 months ago #214993 by purezen
The new editor in 5.2.1 does not allow right-click Paste OR right-click Paste as Plain Text.
It is only allowing CTRL + V to paste
or
CTRL + Shift + V to paste plain text
The average user may know CTRL + V for pasting, but having to use CTRL + Shift + V to paste as plain text is really awkward.
I have never seen any website or forum anywhere, block right-clicking options to Paste.
Can this be fixed ?
I am using Google Chrome.
Seeing this message in Google Chrome is the weirdest most confusing thing I have ever seen.
Last edit: 5 years 9 months ago by purezen.
5 years 9 months ago - 5 years 9 months ago #214999 by xillibit
It's a known issue at CKeditor : github.com/ckeditor/ckeditor4/issues/469 , someone has put a workaround in this issue. I need to try it
Last edit: 5 years 9 months ago by xillibit.
5 years 9 months ago #215012 by xillibit
I have put the code into Kunena, you can try by applying these changes : github.com/Kunena/Kunena-Forum/commit/69...8dd75f07ae4906fc7cae
5 years 9 months ago - 5 years 9 months ago #215028 by purezen
I installed the DEV build pkg_kunena_v5.2.2-DEV_2021-01-03.zip on my TEST site, but it appears to be causing a new problem.
I also tried the newer pkg_kunena_v5.2.2-DEV_2021-01-04.zip and it causes same problem.
After I deleted ALL my Joomla caches and deleted the Google Chrome cache, the new Kunena editor is not displaying at all in 5.2.2.
Please note that I did not experience this problem with Kunena 5.2.1 on my live site using a 9themestore template.
5 years 9 months ago - 5 years 9 months ago #215039 by xillibit
When the editor doesn't be loaded can-you look into the developpement console of your browser into javascript tab if you have some errors ?
5 years 9 months ago #215103 by purezen
Sorry for the delay in replying.
I discovered I had a small Javascript file at the bottom of my forum, that was used to display an SSL certifcate security image.
After turning that module off for my website, the editor now shows again in the DEV build.
However now the OLDER editor is showing instead of new editor ?
I went to see if you had anymore newer DEV nightly builds released, but there are no download links showing at the moment.
I guess they will return soon.
