Solved Kunena Login : problem with characters
10 years 11 months ago - 10 years 11 months ago #170319 by Tassos
I have the following problem :
image missing http://i.imgur.com/WUVieMN.png http://i.imgur.com/emjbRZx.pngg
( Kunena Login 3.1.1 )
I have the Greek language long ago and everything worked fine.
But after an update I noticed this problem.
I was expecting maybe corrected with some updating, but so far nothing has changed.
So please you too can you help?
This problem exists only in "Kunena Login", nowhere else.
Today I reinstalling the "Kunena Language Package" but did not fix anything. :(
I saw the following similar themes, but did not help me :
http://www.kunena.org/forum/kunena-4-0-support-reporting-defects/134600-kunena-latest-module-issue#169541 http://www.kunena.org/forum/k-4-0-support-archive/134708-kunena-latest-module-and-login-form-display-garbled-characters-after-updating-to-4-0-5?limitstart=0
The Greek anywhere work perfectly. Only the " Kunena Login " I have this problem.
Last edit: 10 years 11 months ago by Tassos.
10 years 11 months ago #170321 by rich
Here is the correct file. Please unzip the file and copy them to the folder "root/language/el.GR".
The following user(s) said Thank You: Tassos
10 years 11 months ago #170348 by Tassos
rich wrote: Here is the correct file. Please unzip the file and copy them to the folder "root/language/el.GR".
Perfect, I followed your instructions and now the problem is resolved. :D
Thank you very very much!
Your answer were also so direct... you're unbelievable!! :woohoo:
You are really amazing.
But I would ask .. this problem from where come? I could fix it myself? ( find this file somewhere ...? )
Y.S :. Sorry i'm late to reply (because i saw yesterday your answer ), but today i managed to see.
10 years 11 months ago #170349 by 810
There is a issue with our encoding on our plugins/modules. There is a wrong encoding set. That's why you get this issue.
10 years 11 months ago #170387 by Tassos
810 wrote: There is a issue with our encoding on our plugins/modules. There is a wrong encoding set. That's why you get this issue.
Okay so some time will be corrected.
Thank you very much! :)
Time to create page: 0.430 seconds
