Solved Kunena 4.0.5 - Warning: imagecolorsforindex(): Color index 255 out of range
11 years 2 months ago #167951 by bernard92000
I have this error:
Warning: imagecolorsforindex(): Color index 255 out of range in /libraries/kunena/image/image.php on line 118
This appends only during post viewing with a new avatar (gif with transparently in my case). I think it's during the avatar miniatures creation. When refreshing the page, no more error message (because the avatar miniatures where already created)
I can add @ before imagecolorsforindex() (like it was made into a line for this function into previous Kunena version), but I'd prefer a real fix.
Thank.
11 years 2 months ago #167954 by 810
could you add your avatar settings.
and add the avatar, so i can check the error.
11 years 2 months ago #167955 by 810
try github.com/Kunena/Kunena-Forum/blob/deve...image/image.php#L117
change to
if ($trnprt_indx >= 0 && $trnprt_indx < imagecolorstotal($this->handle)) { // Get the transparent color values for the current image. $rgba = imageColorsForIndex($this->handle, imagecolortransparent($this->handle)); $color = imageColorAllocateAlpha($handle, $rgba['red'], $rgba['green'], $rgba['blue'], $rgba['alpha']); }
11 years 2 months ago - 11 years 2 months ago #167956 by bernard92000
All the install have the default setting:
Allow Avatar Upload : Yes
Use Avatars Gallery : Yes
Max. Avatar File Size : 2048
Avatar Quality : 75 %
Avatar Resize Method : Interpolation (Better - Fast)
Avatar Cropping : No
Note: deleted the picture :P
Last edit: 11 years 2 months ago by bernard92000.
11 years 2 months ago #167957 by bernard92000
For the code test =>
Notice: Undefined variable: color in /libraries/kunena/image/image.php on line 124
