Solved Discuss plugin required field not red
11 years 3 weeks ago - 11 years 3 weeks ago #169050 by xillibit
I have completly forgot this one, i will add it on github to don't forget it
P.S. : Added on github github.com/Kunena/Kunena-Addons/issues/180
Last edit: 11 years 3 weeks ago by xillibit.
The following user(s) said Thank You: ruud
11 years 3 weeks ago #169059 by ruud
Thanks Xillibit :)
perhaps also add the guest alert like it is in the forum (is in the same file: ./plugins/content/kunenadiscuss/tmpl/form.php)
.............. <td valign="top"> <table> <!-- ADDED GUEST ALERT--> <?php if(!$this->user->exists()) : ?> <td></td><td><div class="alert alert-info"><?php echo JText::_('COM_KUNENA_GEN_GUEST'); ?></div></td> </tr> <?php endif; ?> <!-- END ADDITION --> <tr> <td><span class="kdiscuss-quick-post-label"><?php echo JText::_('PLG_KUNENADISCUSS_NAME') ?></span></td ...........
sharing = caring
11 years 3 weeks ago #169063 by 810
done
11 years 3 weeks ago #169154 by ruud
Hi, made a comment on the committed code, not sure if you got that?
sharing = caring
11 years 3 weeks ago #169158 by 810
replied
