Solved Problems with Kunena 4.0.3
11 years 3 months ago #166679 by HardstylerDK
www.elektroniktest.dk/forum/projekter/25...gger-med-thermaltake
When clicking on the "Moderate" or "Handling" or almost any other button, they disappear.
Also, the "white" box under the thumbnails looks weird, and after hovering over this box and moving the cursor, the box disappears.
And the dropdown under the "Handling" button is way off to the left, as seen on the screenshot.
Another thing is that when pressing an image, to open it in a modal window, it takes quite a long time before it opens.
And at last, when clicking the "profile button", the one on the right in the menu, it doesn't open op the dropdown menu, before you move the cursor, and besides that, the status modal doesn't work either.
11 years 3 months ago #166702 by 810
Replied by 810 on topic Problems with Kunena 4.0.3
looks like a jquery conflict. With multiple versions running at once.
try to delete components / com_kunena / template / crypsis / template.php line 95:
JHtml::_('jquery.framework');
And try again.
11 years 3 months ago #166704 by HardstylerDK
This is already commented out, in the template.php.
11 years 3 months ago - 11 years 3 months ago #166713 by HardstylerDK
Another problem i've just found, is that when trying to moderate a topic, i get this:
500 Internal Server Error
Fatal Error was detected!
The error was detected in the Kunena Component.
Fatal Error: syntax error, unexpected 'glyphicon' (T_STRING), expecting ',' or ';' in components/com_kunena/template/crypsisb3/layouts/topic/moderate/default.php on line 62
I've just checked the line and it looks like this:
<input type="radio" id="radio<?php echo $glyphicon glyphicon->id ?>" name="topic_emoticon" value="<?php echo $glyphicon glyphicon->id ?>" <?php echo !empty($glyphicon glyphicon->checked) ? ' checked="checked" ' : '' ?> />
Another thing is that, inside a forum category, which is allowed to be seen by the public/guests, there is a single topic, which can only be seen if you're logged in to the website, but all other topics under the same category is visible, whether or not you're logged in.
Last edit: 11 years 3 months ago by HardstylerDK.
11 years 3 months ago #166717 by xillibit
Replied by xillibit on topic Problems with Kunena 4.0.3
Try line 58 to 69 to replace with that :
<?php if ($this->config->topicicons) : ?> <div><?php echo JText::_('COM_KUNENA_MODERATION_CHANGE_TOPIC_ICON'); ?>:</div> <div class="kmoderate-topicicons"> <?php foreach ($this->topicIcons as $id => $icon): ?> <input type="radio" id="radio<?php echo $icon->id ?>" name="topic_emoticon" value="<?php echo $icon->id ?>" <?php echo !empty($icon->checked) ? ' checked="checked" ' : '' ?> /> <label class="radio inline" for="radio<?php echo $icon->id ?>"> <img src="<?php echo $this->template->getTopicIconIndexPath($icon->id, true); ?>" alt="" border="0"/> </label> <?php endforeach; ?> </div> <?php endif; ?>
11 years 3 months ago #166718 by HardstylerDK
That worked.
Now i've just got these anoying problems with tabs and buttons disappearing whenever i click or hover over them.
