Solved Installation Fail Issue
10 years 6 months ago #174507 by ptruble
I have tried unsuccessfully to install Kunena 4.0.10 into my Joomla 3.5.x. I get the attached message. Does anyone have an idea how I fix said issue?
Thanks!
10 years 6 months ago #174519 by ptruble
Replied by ptruble on topic Installation Fail Issue
So after reading through the forum, I found that getting the Github verson of the Kunena Package may work, and it did. Just wanted to letanyone else having this probelm know a possible fix.
The following user(s) said Thank You: xristo
10 years 6 months ago #174740 by Nikiniko
Replied by Nikiniko on topic Installation Fail Issue
where did you find it ?
I found only 5 or 3.
Thank you
