Question Installation fails. No access to "/site/administrator.index.php
10 years 6 months ago #174646 by lister171254
It's not a firewall issue, as stopping the firewall and clearing all iptables still gives the error. Looked at the apache error log and found this.
[Thu Apr 28 12:06:29.577575 2016] [:error] [pid 14485] [client 60.225.3.224] ModSecurity: Access denied with code 403 (phase 2). Match of "eq 0" against "MULTIPART_UNMATCHED_BOUNDARY" required. [file "/etc/modsecurity/modsecurity.conf"] [line "81"] [id "200003"] [msg "Multipart parser detected a possible unmatched boundary."] [uri "/dc3/administrator/index.php"] [unique_id "VyFwE5ZrSWQAADiVOEAAAAAD"]
10 years 6 months ago #174656 by xillibit
So, did-you have tried to disable mod_security to see if it's works better ?
10 years 6 months ago #174713 by lister171254
Yes, have disabled rule MULTIPART_UNMATCHED_BOUNDARY, and the installation works.
Trailing through the net, it seems to be related to lines starting with "--" for example
curl 'https://localhost/group/control_panel/manage?p_auth=MWq0gmZw&p_p_id=166&p_p_lifecycle=1&p_p_state=pop_up&p_p_mode=view&doAsGroupId=10328&refererPlid=10331&controlPanelCategory=current_site.content&_166_refererPortletName=15&_166_refererWebDAVToken=journal&_166_scopeTitle=Templates&_166_struts_action=%2Fdynamic_data_mapping%2Fedit_template' -H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8' -H 'Accept-Encoding: gzip, deflate' -H 'Accept-Language: en-US,en;q=0.5' -H 'Connection: keep-alive' -H 'Cookie: JSESSIONID=E10AB37213FD6D61DE10A72AB8FF1A3A; LFR_SESSION_STATE_10345=1390888801890' -H 'DNT: 1' -H 'Host: localhost' -H 'Referer: https://localhost/group/control_panel/manage?p_p_id=166&p_p_lifecycle=0&p_p_state=pop_up&doAsGroupId=10328&refererPlid=10331&controlPanelCategory=current_site.content&_166_refererPortletName=15&_166_refererWebDAVToken=journal&_166_scopeTitle=Templates&_166_cmd=update&_166_struts_action=%2Fdynamic_data_mapping%2Fedit_template&_166_redirect=https%3A%2F%2Flocalhost%2Fgroup%2Fcontrol_panel%2Fmanage%3Fp_p_id%3D166%26p_p_lifecycle%3D0%26p_p_state%3Dpop_up%26p_p_mode%3Dview%26doAsGroupId%3D10328%26refererPlid%3D10331%26controlPanelCategory%3Dcurrent_site.content%26_166_refererPortletName%3D15%26_166_refererWebDAVToken%3Djournal%26_166_scopeTitle%3DTemplates%26_166_groupId%3D10328%26_166_showHeader%3D0%26_166_classNameId%3D10102%26_166_eventName%3DselectStructure%26_166_struts_action%3D%252Fdynamic_data_mapping%252Fview_template&_166_templateId=10850&_166_groupId=10328&_166_classNameId=10102&_166_classPK=0&_166_type=display&_166_structureAvailableFields=' -H 'User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:26.0) Gecko/20100101 Firefox/26.0' -H 'Content-Type: multipart/form-data; boundary=
1835282785777842564651277339' --data-binary $'Content-Type: multipart/form-data; boundary=
1835282785777842564651277339\r\nContent-Length: 3492\r\n\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_formDate"\r\n\r\n1390888796288\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_cmd"\r\n\r\nupdate\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_redirect"\r\n\r\nhttps://localhost/group/control_panel/manage?p_p_id=166&p_p_lifecycle=0&p_p_state=pop_up&p_p_mode=view&doAsGroupId=10328&refererPlid=10331&controlPanelCategory=current_site.content&_166_refererPortletName=15&_166_refererWebDAVToken=journal&_166_scopeTitle=Templates&_166_groupId=10328&_166_showHeader=0&_166_classNameId=10102&_166_eventName=selectStructure&_166_struts_action=%2Fdynamic_data_mapping%2Fview_template\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_closeRedirect"\r\n\r\n\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_portletResource"\r\n\r\n\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_templateId"\r\n\r\n10850\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_groupId"\r\n\r\n10328\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_classNameId"\r\n\r\n10102\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_classPK"\r\n\r\n0\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_type"\r\n\r\ndisplay\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_structureAvailableFields"\r\n\r\n\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_saveAndContinue"\r\n\r\n1\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_name"\r\n\r\nTest\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_name_en_AU"\r\n\r\nTest\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_language"\r\n\r\nftl\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_description"\r\n\r\n\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_description_en_AU"\r\n\r\n\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_smallImage"\r\n\r\nfalse\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_type"\r\n\r\nfalse\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_smallImageFile"; filename=""\r\nContent-Type: application/octet-stream\r\n\r\n\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_scriptContent"\r\n\r\n<#--\r\nDisplay templates are used to lay out the fields defined in a data\r\ndefinition.\r\n\r\nPlease use the left panel to quickly add commonly used variables.\r\nAutocomplete is also available and can be invoked by typing "${".\r\n-->\r\n
1835282785777842564651277339\r\nContent-Disposition: form-data; name="_166_script"; filename=""\r\nContent-Type: application/octet-stream\r\n\r\n\r\n
1835282785777842564651277339--\r\n'
10 years 5 months ago #174905 by NAIDW
We are having problem also? Ours was already installed and we did not even try to update but getting error and will not even allow to forum backen has attached pice error.
A few days before this happened i noticed something weird on the back end when we accesed forum it was showing a login module.
Can someone help us we do not know how to fix or do these things we are a small nonprofit with volunteers and we recently lost our admin/volunteer
10 years 5 months ago #174921 by lister171254
Following is my workaround for this.
I'm running apache on 64 bit Ubuntu
  1. Edit the file /etc/modsecurity/modsecurity.conf
  2. Comment out the two lines starting with SecRule MULTIPART_UNMATCHED_BOUNDARY "!@eq 0" \
    "id:'200003',phase:2,t:none,log,deny,msg:'Multipart parser detected a possible unmatched boundary.'"
  3. Restart Apache
Once Kunena is installed/upgraded reverse the changes and restart Apache
As an aside, it would be great if the developers could fix this
The following user(s) said Thank You: xristo
10 years 5 months ago #174936 by xillibit
There is an issue opened on modsecurity similar to our : github.com/SpiderLabs/ModSecurity/issues/652
