Solved Preparing Installation failed Ver. 4.0.10
10 years 9 months ago #173217 by ferdinand
Hi, i have tried to install Kunena 4.0.10 on a debian(Jessy) box with joomla 3.4.8 but the installation failed with an error at Installation preparation - see image.
I have checked the requirements for apache and php, also the file permissions and everything looks fine.
Other extensions/moduls install without problems. I also tried it on a fresh installation of joomla with the same result. I have tried to install from uploaded package file, from url and from the web
There is mentioned that i should post a configuration report. Where do i find this report?
Thank you for your help.
10 years 9 months ago #173260 by 810
Hi sometimes there is a issue that you can't install the component, we still are looking at it, but we haven't located the real issue.
For the moment after the error go to:
yoursite/administrator/index.php?option=com_kunena
Then the installer will complete.
ps when the installer is working then you can get the report, on kunena - tools - report
10 years 9 months ago #173299 by ferdinand
when I go to administrator/index.php?option=com_kunena
the same error is displayed.
Any other ideas?
10 years 9 months ago #173306 by 810
check the extension updater, that all are updated, and try again
10 years 9 months ago #173308 by ferdinand
the other extensions (backup and admin tool - its nearly a brand new joomla installtion) are updated
there is still the same installation failure
10 years 9 months ago #173311 by 810
is your database utf8mb4? i just confirmed this with that collation. We need to add support for it.
