Solved Problem with writing new posts
Recently I changed my host company and transfer all information to a new one.
I think after that I start getting this problem when I try to make new post, answer in some topic and etc:
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ' 'test')' at line 1 SQL=INSERT INTO fresh_kunena_messages_text (mesid, message) VALUES (, 'test')
I though that maybe is from my Joomla 2.5 site and after that I migrated to J3.4, but have the same problem.
Can you help me with solving this issue?
I will be really thankfull!
Thank you in advance!
Go to yoursite.com/administrator/index.php?option=com_kunena&view=tools&layout=diagnostics
And see if there any issue's.
I think you need to check the tables from the old site. And do the exporting again
I add aliases to this 3 categories and now all test are passed with this checking configuration, but I still have the same problem:
Can't make new topis, can't answer too.
Do you have any other idea about this?
Maybe if there is configuration file for kunena, for writing new details for my new hosting, maybe this can be a problem?
Can you help me solving this, please?
I don't have an answer from a 5 days.
Is there anything else I can do to fix this problem, because it's very important to save this forum and make it working ...
