Solved Kunena seems to work well, except if I link directly to the forum
10 years 4 months ago - 10 years 4 months ago #172459 by fribse
I haven't seen any errors up until now, and then I sent a link to a developer for helping out with some template problems.
But if I link directly to the 'create a new post', I get an error:
Notice: Trying to get property of non-object in xxx/components/com_kunena/views/topics/view.html.php on line 358
Fatal error: Call to a member function get() on null in xxx/components/com_kunena/views/topics/view.html.php on line 359
So the situation is that the user is not logged in, and then go to www.dkdb.dk/forum/nytemne
It doesn't happen if the user logs in first, and then go to the URL.
What to do?
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 512M | Max file upload: 256M
Joomla default template details : joomspirit_113 | author: JoomSpirit | version: 1.1 | creationdate: 26/07/2015
Kunena default template details : NTS KPyrite | author: Nice Theme Store | version: 3.5.0 | creationdate: 2013-12-24
Kunena version detailed: Kunena 4.0.8 | 2016-01-12 [ Tokyo ]
Third-party components: CommunityBuilder 2.0.12 | UddeIM 3.8
Plugins: Search - Kunena Search 3.1.2
Modules: Kunena Latest 3.1.2
Best regards
Fribse
Dykkerklubben Dannebroge www.dkdb.dk
We're a volunteer driven diving club in Mosede, Denmark.
Har du brug for en dykkerklub der rummer alle, så kom ned til os.
Last edit: 10 years 4 months ago by fribse.
10 years 4 months ago #172463 by xillibit
This error has been fixed into Kunena 4.0.9, so i suggest you to do a backup and do the update to 4.0.9 version
The following user(s) said Thank You: fribse
10 years 4 months ago #172498 by fribse
You're absolutely right, thankyou!
Best regards
Fribse
Time to create page: 0.235 seconds
