Solved Error after up grading to 4.0.8
10 years 10 months ago - 10 years 10 months ago #172241 by JCPO
After having upgraded to Kunena 4.0.8 and being with Joomla 3.4.8 I have following message when trying to get onto my site forum:
500 Internal Server Error
Fatal Error was detected!
The error was detected in the Kunena Component.
Fatal Error: Call to a member function get() on a non-object in components/com_kunena/views/category/view.html.php on line 653
For support click here: Kunena Support
Go back
the line 653 is following: $cachegroup = 'com_kunena.category';
Every thing was ok before up grading. Any help?
Last edit: 10 years 10 months ago by JCPO.
10 years 10 months ago #172245 by 810
Replied by 810 on topic Error after up grading to 4.0.8
this is a know issue, we are trying to fix this issue.
in the mean time, you can overwrite the file, from K4.0.7
10 years 10 months ago #172254 by sozzled
810 wrote: this is a know issue, we are trying to fix this issue.
If this is a known issue, can you please quote the GitHub reference? We would like to know how and when this problem is fixed. Thank you.
10 years 10 months ago #172257 by 810
we have no fix at the moment, we are trying to collect some details from other users.
There are reports from this issue, but for now we can't reproduce the issue. Its seems its caused by an old/outdated php versions.
10 years 10 months ago #172261 by sozzled
810 wrote: There are reports from this issue ...
Do you have links to these reports, please? If there are reports of problems with the installation of K 4.0.8, I think the community would like to follow this issue.
810 wrote: [It seems likely] caused by an old/outdated php versions.
Which "old/outdated" PHP versions seem to be likely causes of the problem?
Thank you.
10 years 10 months ago - 10 years 10 months ago #172262 by 810
if you go to recent, then you see issues with 4.0.8, that are all the same issue:
like www.kunena.org/forum/k-4-0-installation-...a-4-0-8-uddeim-issue
I haven't reproduce the issue, so i can't tell why it isn't working correct.
Last edit: 10 years 10 months ago by 810.
