Solved kunena 4.0.8 simple membership issue
10 years 10 months ago #172108 by Nikiniko
After updating to kunena 4.0.8 from kunena 4.0.7,
the link for membership payment is not working.
From simple membership i had this responce :
We've checked this problem on your website and found, that if plugin System - Kunena Forum is turned off, all works.
We don't know for what this plugin is. I can recommend you contact the Kunena team and ask them why it can break our component.
Can you help or do i have to downgrade to kunena 4.0.7 ?
Thank you
10 years 10 months ago #172109 by xillibit
Which payment component or plugin are-you using ?
10 years 10 months ago #172113 by Nikiniko
There is a link to paypal for the membership but is not working.
10 years 10 months ago #172115 by 810
when you enable the kunena plugin. Could you also enable debug on the kunena configuration. then you see the real error message. But i think there is a bug on that component
10 years 10 months ago #172116 by Nikiniko
Where suposed to be the message ?
