Solved The installation progress fail
10 years 10 months ago #171778 by acghedini
I'm using a Joomla 3.4.8 and i already had installed kunena, however I had to delete that site and now i´m having de following issue when i´m trying to install the forum:
Warning: DOMDocument::load(): I/O warning : failed to load external entity "/home/reinodai/public_html/webstudio/administrator/KPATH_ADMIN/install/install.xml" in /home/reinodai/public_html/webstudio/administrator/components/com_kunena/install/schema.php on line 281
Warning: Invalid argument supplied for foreach() in /home/reinodai/public_html/webstudio/administrator/components/com_kunena/install/schema.php on line 422
Fatal error: Class 'KunenaRoute' not found in /home/reinodai/public_html/webstudio/administrator/components/com_kunena/install/sql/install/php/sampledata.php on line 147
Please, can anyone help?
Thanksa lot
Alan.
10 years 10 months ago #171782 by 810
Replied by 810 on topic The installation progress fail
are you using CB?
10 years 10 months ago #171783 by acghedini
Yes. CB 2.0.12
10 years 10 months ago #171787 by 810
try to disable the cb system plugin, then install kunena, then enable the plugin again. This bug will be fixed in cb 2.0.13
10 years 10 months ago #171792 by acghedini
It's working now.
Thank you! :)
10 years 10 months ago #172152 by bnickles1961
I am having the same problem I have tried to install Kunena 4.0.7 & 4.0.8 I am running Joomla 3.4.8 and I get the same installation error mentioned earlier in this thresd. The only difference is that I am NOT running community builder. How would I get this to install properly? Thanks in advance
