- Thank you received: 1
Question Installation/Upgrade to Kunena 4.0.7 fails on Joomla 3.4.7
10 years 4 months ago - 10 years 4 months ago #171484
by csommer
I get the following error when upgrading to Kunena 4.0.7 on Joomla 3.4.7:
This error does not go away even after clearing the administrator cache and re-installing Kunena.
I was able to upgrade to Kunena 4.0.7 on another site on Joomla 3.4.6 however, and so to overcome the above error, I had to roll back the Joomla 3.4.7 update. After upgrading to Kunena 4.0.7 successfully I reinstalled the Joomla update and everything sees to work fine now.
Last edit: 10 years 4 months ago by csommer.
10 years 4 months ago #171485
by Tom01
Replied by Tom01 on topic Installation/Upgrade to Kunena 4.0.7 fails on Joomla 3.4.7
I updated from joomla 3.4.5 to 3.4.7. that works.
after that I tried to update kunena from 4.0.5 to 4.0.7.
But I've got the same error like above.
I did some things:
- delete admin cache for kunena
- installed the 4.0.8 version that posted from a developer in the forum
- installed the joomla update again
But nothing works. Kunena forum is offline.
Hope somebody can help me!!!
Tom
I did some things:
Tom
10 years 4 months ago #171486
by 810
Replied by 810 on topic Installation/Upgrade to Kunena 4.0.7 fails on Joomla 3.4.7
try to go to administrator/index.php?option=com_kunena&view=install
and see if the installer runs.
If you have cb installed try to disable system - cb, install kunena, and enable it again.
10 years 4 months ago #171493
by Tom01
I don't use CB.
I did reinstall an backup. I will try it later again.
Before I have to update the kunena template as well (9theme).
and I had the kunena 4.0.3 (not 4.0.5).
I will inform you.
I will inform you.
10 years 4 months ago #171495
by 810
there is a bug with sessions on j3.4.7. Try to cler session on admin tools. Or logout then login again on the backend.
10 years 4 months ago #171502
by Tom01
One day later - it works.
I tried it again. Before I cleared the admin cache and start the install process again.
I don't know why, but it works.
thanks
thanks
Time to create page: 0.227 seconds
