Solved [SOLVED] Installation conflict with Community Builder
11 years 2 weeks ago - 11 years 2 weeks ago #170108 by gpeterson
I tried to install Kunena v4.0.6 all day. The progress bar would freeze at the beginning. It crashed both the frontend and backend. I reinstalled the website from backup a dozen times.
The problem turned out to be a conflict with Community Builder which I had previously installed.
The solution was to keep the Akeeba installation "Login to backend" window open. After a Kunena installation crash, I could click on the Akeeba link to get back in to the backend. Then I went to Components/Kunena Forums/Plugins and activated "Kuenena - Community Builder Integration". Then clicking on the "Kunena Dashboard" continued the installation process to completion.
Windows Server
Joomla 3.4.5
Last edit: 11 years 2 weeks ago by gpeterson.
