Question upgrade
Now forum is stuck in maintenance mode and won't install. What do I need to do to fix this?
You may still be able to access your configuration report . If you can access your configuration report, it may help to post the information here.sublevel4 wrote: Now the forum is stuck in maintenance mode and won't install.
I added the column and then the install worked, not neat and tidy but my forum is back up. Thank you all for the help I wish i could have provided more information to help in the future.
Dylan
- chrimisotof
Kunena installatie mislukt!
SQL Query: UPDATE `#__kunena_user_categories` SET `allreadtime_new`=if(UNIX_TIMESTAMP(`allreadtime`), UNIX_TIMESTAMP(`allreadtime`), `allreadtime`); ... FAILED
Bereid installatie voor ... OK
Bezig met installeren van Kunena - Alphauserpoints plugin ... OK
Bezig met installeren van Kunena - Community plugin ... OK
Bezig met installeren van Kunena - Comprofiler plugin ... OK
Bezig met installeren van Kunena - Gravatar plugin ... OK
Bezig met installeren van Kunena - Uddeim plugin ... OK
Bezig met installeren van Kunena - Kunena plugin ... OK
Bezig met installeren van Kunena - Joomla plugin ... OK
SQL Query: ALTER TABLE `#__kunena_user_categories` DROP `allreadtime` ; ... FAILED
SQL Query: ALTER TABLE `#__kunena_user_categories` CHANGE `allreadtime_new` `allreadtime` INT(11) NOT NULL DEFAULT '0'; ... FAILED
SQL Query: UPDATE #__kunena_user_categories AS c INNER JOIN #__kunena_sessions AS s ON c.user_id=s.userid SET c.allreadtime=s.lasttime WHERE c.category_id=0 AND s.lasttime>c.allreadtime; ... FAILED
Database bijgewerkt naar versie 3.0.94 ... OK
