Solved Language problem in Crypsis template
11 years 3 months ago #167577 by tomsson
htaccess: Exists | PHP environment: Max execution time: 150 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : sj_news | author: YouTech Company | version: 2.0.2 | creationdate: Unknown
Kunena default template details : Crypsis | author: Kunena Team | version: 4.0.3 | creationdate: 2015-06-29
Kunena version detailed: Kunena 4.0.3 | 2015-06-29 [ Possagno ]
Third-party components: CommunityBuilder 2.0.10 | UddeIM 3.7
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.7
Modules: Kunena Latest 3.0.1
I just update Kunena from 3.0.8 to 4.0.3 and install CRYPSIS template and set as default template and I install language pack for 4.0.3
But I got language problem
Many things dont have translations
example: COM_KUNENA_MESSAGE_CREATED, COM_KUNENA_MESSAGE_CREATED ...
see also in attachment
11 years 3 months ago #167580 by rich
Polish language strings are not 100% translated. You have setting in the configuration (tab General) "Use English On Missing Strings = Yes"?
11 years 3 months ago #167583 by tomsson
yes, I have sett but not working
11 years 3 months ago - 11 years 3 months ago #167585 by rich
[strike]Have you enabled the Kunena debug mode? Debug mode disables the feature Use English On Missing Strings.[/strike]
Sorry, I see in the configuration report, this setting is correct.
Last edit: 11 years 3 months ago by rich.
11 years 3 months ago #167586 by tomsson
rich wrote: [strike]Have you enabled the Kunena debug mode? Debug mode disables the feature Use English On Missing Strings.[/strike]
Sorry, I see in the configuration report, that the setting is correct.
yes, and not working
is a bug?
11 years 3 months ago #167587 by rich
hm.. maybe it's a bug, but I'm not sure. Let's wait what the developers think.
Time to create page: 0.156 seconds
