Question K 4.0.2 needs PHP 'fileinfo'
The issue only happens with blue eagle and legacy templates not with crypsissozzled wrote:
True. I was able to install K 4.0.2 on my website by changing the install.script.php file. But it is not possible to upload attachments ... even with Blue Eagle!xillibit wrote: You revert this change in the K4.0.2 package : github.com/Kunena/Kunena-Forum/commit/6d...707e544117f99f49516e
in order to be able to install k4.0.2 ...
The requierement was to avoid this fatal error, the fileinfo php extenion is needed to use FINFO class so it's the reason of this fatal errorsozzled wrote: There is an additional dependency involved.
If people do not have the PHP fileinfo extension enabled (and that is 9 out of 10 people on a shared webhosting environment) then they will not be able to upload attachments even if they use Blue Eagle (or another template derived from Blue Eagle—and that's 99% of all alternative Kunena templates).
So there is more than just a one-line change involved here.
Here is the replay from my webhosting provider:
"Hello,
For security reasons this extension is not active in Shared Hosting environment. If your application for operation necessarily requires this, we recommend you to orientate your attention to a dedicated solution (VPS or dedicated server) where you can create your own security policy in terms of extensions used."
And i don't think many people will be able to solve this very fast.
I really hope that Kunena Team will be able to find a workaround.
I totally agree with you. Further, the additional dependency on the fileinfo extension should have been highlighted in both the release notes and in the technical requirements documentation. This important information is missing in both places.skybax wrote: This change should have been implemented with a toggle and retain old functionality and also add the new one for compatible environments, because we need to be honest here most of us wont be able to implement the new changes from kunena overnight. If the implementation of PHP 'fileinfo' would have been announce before the release the K 4.0 Beta 1 we could have
I have spent the past three weeks trying to work with K 4.0. It has been a difficult time. Again, I agree with you and being just as totally honest, most of us will not be able to absorb the new changes overnight.
Like you, I have only in the last month re-contracted for another three years a shared hosting plan. The difference between a shared hosting plan costing $300 for three years and a VPS solution costing $300 per month is considerable and we're not all as fortunate as those who have access to this kind of money.skybax wrote: Here is the reply from my webhosting provider:
"Hello,
And I don't think many people will be able to solve this very fast.
Like you, I also wrote to my webhosting provider but, unlike you, I luckily received a favourable response to enable the PHP fileinfo extension. I am now able to upload images on my forum using any of Crypsis, Blue Eagle or any of the templates that I developed myself.
The main issue here is that a change was introduced by the development team that can paralyse people wanting to upgrade from K 3.0.x or K 4.0.x before the current version. The change can effectively cripple anyone who uses the Blue Eagle template or templates derived from Blue Eagle.
We really should not have to be doing "trial-and-error" to see what works and what does not work. I always read the release notes and technical information to see what I need before I attempt to upgrade any software. The vital information—that K 4.0.2 has a pre-installation check relating to the PHP fileinfo extension—was missing in the announcement, in the release notes and in the technical requirements guide.
Perhaps the development team has overlooked the fact that almost all alternative templates for Kunena are derived from Blue Eagle? Perhaps the Kunena developers are unaware that not everyone is as enthusiastic about Crypsis as they are?
In any event, I really feel very sorry for skybax and other members of the community who are like him.
This is an important topic! I repeat my request to have this topic made sticky to draw people's attention to the fact that they cannot install K 4.0.2 unless they have the PHP fileinfo extension enabled. Futher, the topic needs to be stickied because, even if people do install K 4.0.2 by using the techniques we have discussed, if they do not have the PHP fileinfo extension enabled on their webhost they will not be able to upload attachments using the Blue Eagle template.
www.drupal.org/node/2290261
In my opinion, you should fix this and maybe throw in a few quick fixes and release this as 4.0.3 ASAP.
