Question Post installation issues.
11 years 5 months ago #166124 by dariushde
I just installed Kunena successfully without a problem, but when I try to go to my Components --> Kunena it gives me the error below:
Table 'ab57583_jmln2.uh46v_community_groups_members' doesn't exist SQL=SELECT g.memberid AS user_id, c.id AS category_id, 2 AS role FROM uh46v_kunena_categories AS c INNER JOIN uh46v_community_groups_members AS g ON c.accesstype='jomsocial' AND c.access=g.groupid WHERE c.published=1 AND g.approved=1 AND g.permissions='COMMUNITY_GROUP_ADMIN'
How can I fix that?
Thank you
11 years 5 months ago #166125 by 810
Replied by 810 on topic Post installation issues.
you have a broken jomsocial installation. Did you update it from an older version.
11 years 5 months ago #166126 by dariushde
Replied by dariushde on topic Post installation issues.
thank you for your response,
no this was a brand new installation!
11 years 5 months ago #166129 by 810
without jomsocial ?
11 years 5 months ago #166130 by dariushde
No I don't have jomsocial! I have bought Easyprofile though. Is it possible to connect that to kunena?
11 years 5 months ago #166131 by 810
yes they have a kunena plugin.
On the issue:
on the plugin manager try to disable the kunena jomsocial plugin.
The following user(s) said Thank You: dariushde
