Solved Images is not upload
11 years 4 months ago - 11 years 4 months ago #165673 by men1079
Images is not upload was created by men1079
Hello, after upgrade to Kunena 4.0 images is not upload to forum. Uploads finished with error code: "COM_KUNENA_UPLOAD_ERROR_AVATAR_EXCEED_LIMIT_IN_CONFIGURATION". If i reduce size of image to 50kb, uploads finished with "500 Internal Server Error Fatal Error was detected! Please contact the site owner."
How I can resolve this?
Last edit: 11 years 4 months ago by 810.
11 years 4 months ago #165678 by 810
Replied by 810 on topic Images is not upload
we just released K4.0.1 Try that first.
When fails, enable kunena debug on config, then check again, then you will see the true error message
11 years 4 months ago - 11 years 4 months ago #165795 by men1079
Replied by men1079 on topic Images is not upload
K4.0.1 didn't help me:(
For example, when i upload image 160kb (in config upload limit for images is 1024kb), kunena used "avatar" configuration (limit 65kb) and show "UPLOAD_ERROR_AVATAR_EXCEED_LIMIT_IN_CONFIGURATION"
When i upload image 60kb (less when avatar limit), i see "fatal error 500"
Debug is on, but it don't show additional error messages
My config:
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 64M
Joomla default template details : rt_kirigami | author: RocketTheme, LLC | version: 1.10 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.1 | creationdate: 2015-06-10
Kunena version detailed: Kunena 4.0.1 | 2015-06-10 [ Alto ]
Third-party components: UddeIM 3.5
Plugins: None
Modules: Kunena Latest 3.0.1
Last edit: 11 years 4 months ago by men1079.
11 years 4 months ago #165943 by men1079
Do anybody help me? Maybe i should reinstall kunena/joomla (without delete SQL tables)? It is very strange.. Maybe problem on hosting (inactive modules, incompatible versions..)?
Thanks in advance.
11 years 4 months ago #165944 by rich
Replied by rich on topic Images is not upload
The following user(s) said Thank You: men1079
11 years 4 months ago #165946 by men1079
Unfortunately, this is not my case. When i increase the avatar size, i see "Error 500"
Time to create page: 0.152 seconds
